Darren, I'm pretty sure he was hearing "ping" (probably under load), if you read the first post carefully. I don't think he had the other symptoms you mentioned.
Ok thanks. I should probably study these things further. I never understood what 'ping' is, is that when WOT and the rev limiter is bouncing off?
