Hi Chris - The 08's have a somewhat different power curve than earlier models. I think they DO drop off later. I know your engine can develop more power and torque than mine.
Regardless, I really think Bill will set the WOT shifts at the correct points to get you what you want. And, thinking about it a bit more, it makes sense to set the shift point somewhat past the peak HP and torque point because then the shift will bring in the next gear at a higher RPM setting, overall, giving you better acceleration (if WOT acceleration is your bag). This of course means the max RPM has to be set higher too, so that the shift can complete properly.
I DO want the acceleration, but I'm also interested in protecting the transmission, which I feel is a weak link in this truck. (Wish it was a manual).
