Originally Posted by TJ05FX4
I'm invoice 1774 so I hope he is working on tunes now
I just checked your UserCP and that invoice number does not match your listed Serial Number, it's not even close!
If I were you, I'd go out to my truck, turn the ignition on (leave the engine off) and select: Diagnostics->Tech Support->Version Info. Ignore the warning message that comes up. Your Serial Number should be on the screen along with some other information, and in general, it should match your invoice number.
Use the Menu key to back out to the display screen and shut everything off.
Make sure Corey has a correct value for your Serial Number, because that's how Bill codes your tunes so that YOU can get them.
