Originally Posted by cleatus12r
Oh...sorry!
The Low Boost Fuel maps usually run from 30-100 (I'll guess percentage) based on MAP pressure. Going above 100 is probably going to give the same effect as youravatar.....just revving up. I have had no need to even try it.
So... It would just shoot as much fuel as you commanded based off of throttle input? I wish I could build my own tunes... I'd have to try that... Just to see.
I'm gonna throw a quick question in instead of starting a thread.
How much can you control as far as shifting? Would there be a way to keep your truck from downshifting too soon? In case that's not clear. Pretend you're cruising in OD, and you want to "roll into it" semi aggresively, could you keep it from kicking down a gear until you hit, say 85% throttle?
My tunes are pretty good at it, I'm just trying to figure out if that's an option.
Can you PM me where you saw that tune?
ONE MORE THING.
Could you check out my buddy RedSmokey's thread on PSN? About the trouble they're having with the injectors buzzing... You're good with that stuff aren't you?
http://powerstrokenation.com/forums/...ad.php?t=43155
