Sun, January 30th, 2011, 06:55 AM
Originally Posted by hampsterzone
Moving the MAF sensor doesn't cause lean codes.
I have always read that the reason you get lean codes is because you move the MAF.
Low back pressure cause the lean codes. Which makes sense cause I never had a lean code with my edge and CAI alone.
Backpressure is supposedly just a myth. I never had a lean code with my EDGE and CAI but I did get other codes because the truck wouldn't run correctly since the CAI changed the MAF location. Custom tunes on my Gryphon fixed that. A lot of people with EDGEs and 5.4Ls got lean codes with CAIs though.
