Interesting - I never slow down with the "coast" button. If I need to reduce speed, I just tap the brake to turn off cruise and then reengage it at the new desired speed. Likewise, to speed up to a new higher speed, I use the gas pedal and then tap "Set" when I reach the speed I want. So, I've never felt what you feel.
The transmission MAY not unlock the Torque Converter to coast down using your method, then when you release the button you'd feel a "lurch". I know with my method, the TC unlocks during coasting, which saves gas, but it takes a bit longer to reach the new speed.
