OK, so let me see if I understand the "load previous settings" option. I am going to eventually get slightly bigger tires when these stock 31's wear out. May go with 33's at the most. If I change the TS/GR correctly to the custom tunes you are doing for me now, then I can just load previous settings when I switch back and forth from perf to tow and vice versa? Or, do I have to enter in the TS/GR each time I change back and forth? I hope not since I do tow a boat about 3-4x per month during the Spring-Fall months. Thanks for clearing it up a bit.
Mark
