Tire Size
Should the tire size be set at actual size according to the chart or allow for a "squish" factor. I currently have the stock 255/70/17 tires inflated to 37#.
I have the tuner set with a 3% squish factor that I have read about in some threads on FTE. Was wanting to make sure the setting is correct to get accurate benefit from the tunes. Thanks.
