Originally Posted by 96grimreaper
Since I do not have any major mods, should I get a custom tune or will the canned tunes suffice?
If I do go with a custom tune will the 87 canned tune be considered the "economy tune"?
Again, if I go with a custom tune I'd opt for the 91, if everyone else thinks the 91 over the 87 would be worth it.
I daily drive the truck approximately 100 miles a day, mostly highway. Truck occasionally tows, and I do go out and play in the mud/sand.
Im just looking towards the experts here for opinions because I've convinced myself I need a tuner. Thank you in advance.
Well the Canned will "suffice", as in they will drastically improve your performance over stock, but custom tunes are better and safer for your truck because they account for your driving habits, if you tell Bill about them that is. I always recommend custom tunes because of the specialization that they provide to you, your truck, and your driving habits.
If the truck is designed to run 87, I vote to run 87. it is cheaper, and the 91 will not be much of a benefit, if any at all. Jackandjanet agrees with me on this(well actually I agree with him on that
), since you dont have a higher compression engine you will not need the extra octane. the benefit it does provide is a slower more controlled burn, so bill would advnace the timing in his tunes, and might even adjust the shift points slightly for the higher octane, but being gas prices are going up, I still vote for 87.
Bill does not provide any sort of "economy" tune because of past tunes of that nature all received complaints because they werent what the owners expected nor wanted. the performance tune is the economy tune. A performance tune makes the engine run as efficient as possible to get the best power, but efficiency also make it run more economical. if you can get more power out of the same amount of gas, then you will need less gas to drive the same speed, but you will use more gas to get the extra power, and if you drive like me, you wont see much improvements in gas mileage because of your leadfootedness...
I would get a tow tune as well. Use it for whenever the truck is really straining itself such as towing, or if you think you may get stuck in the mud. Make sure that whenever you switch tunes that you do it either at home, or close to a tow truck place because although rare with the newer trucks and Gryphons, it is always possible that something goes wrong and makes your truck unusable.
I dont consider myself an expert, and my disclamer is always to see what anyone else says because I get thing wrong sometimes
. Either way I hope I helped answer your questions.
