Originally Posted by syntaxterror
Hi Absolution
What road ranger transmission are you going to use?
Any used RTLO 13 speed to be honest. Just so long as it has a sae-2 bell housing which I found a company that will find and install the correct bellhousing from their yard. The one in looking at currently is a RTLO-16713 mainly due to it having a PTO pump on it already.
I ordered a oem 206ss (FP62062RS2) bearing which im going to check and make sure it's the correct inside diameter 1.18".
I'll probably also have to get the drive shaft shortened.
There is a guy on the trucker forum who convert his dt466 to a RTO6613. His was a complete drop in from a 6plus.
Edit: if you have an automatic there is a chance it's an sae-3 bellhousing.
