MFD is in Milligrams per stroke.. its not a percentage. but it is a Desired which means it not always what you are really getting as several factors affect the actual fuel delivered.
The Map itself in using Accelerator pedal position 0-1024 A/D counts and engine RPM to the the MG/Stroke value...
You will find that there are many values that cannot be set directly because there are many other maps and parameters that alter the individual map..
Start of Injection (SOI) is probably the best example of that.... just cuz u set a SOI at a specific point, you will rarely actually get that SOI
ASE Master Auto Technician
2001 Ford Excursion 7.3 4x4
