Originally Posted by boto
I discovered my truck (06 F-150 5.4 S cab XLT 4x4) has a dead battery and have hooked it up to my bat charger on 2A autocharge regular. The batt was so dead the key fob wouldn't unlock the door, neither would the pin code on the door. Had to use the key. Also, the headlamps will not turn off while I'm charging it. The Gryphon is VERY dimly flickering while on charge. Should I have disconnected the Gryphon before charging?
Move your headlight switch from "Auto" (11:00 O'clock) to "Off" (straight up). If that doesn't turn the headlights off, I'd disconnect the negative battery cable. I don't think a 2 Amp charger can keep up with the draw from headlights. And yes, don't leave the Gryphon connected.
