Thread: Rev-X Testing
Old Mon, June 13th, 2011, 07:58 PM
atk's Avatar
atk atk is offline
atk
atk is on a distinguished road
well it`s about time you got a 6.0L....
i will be following this closely. should i expect somewhat close HP/TORQUE numbers when i am using 140hp program?
anyway, i am very pleased with all programming that has been done. haven`t had a chance to try 80hp dd program yet, been having to much fun with the other 2 programs.....
only issue i have been having is, 3-4 shift(bad flair), maily when the truck isn`t up to operating temp....may try to adjust shift pressure, see if that will help....
as for rev-x, it did help with my truck, but i did have to replace an injector(electrical issue)....i just put some rev-x in a truck(7.3) at work. truck is a very high miler(700000km) with 3 contribution codes. already replaced i injector, do to the fact, it threw a code for that cylinder everytime i did contribution test, the other 2 were hit and miss....will post results after truck is run for a bit....
once again thanks for all the great programming..... (just wish i lived closer, do some fine tuning on the dyno)
2004 FORD F250 4x4 CC SB 6.0L AUTO....
Tuned by PHP.... SCT-X3.... Mbrp duals....and more....
