Computer?
Bill I am having a weird issue with my transmission. It won't shift into OD. The light stays on that shows it to be off. Now if I hook up the Snap On scan tool and run through test it will go off during the test. Its not the wiring in the shifter handle cause that has been changed. No codes and the tranny shifts fine 1-3, full of fluid and its not burnt. Trans temps run under 140 pretty much all the time. Do you have an idea what could cause this in the computer? If you think it would be better if I called and talked to you about it next week I can do that. Its a TDE1 computer code.
Chuck
Chuck
1995 Mustang GT
2004 Explorer Limited
