Code p1151 is a code for the heated oxygen sensor on bank 2 sensor 1. This could be the sensor but could also be caused by a vacuum leak causing a lean condition. There is also an issue with contaminated Mass Air Flow sensors causing this problem. They can be cleaned. there are special cleaners from CRC that you can buy at stores like autozone to do this.
Search also for Ford TSB 98 23 10
