More than normal smoke means you are not getting as much air as before, or the fuel getting injected is not as atomized as it was before (not likely unless you have a CEL) .
I would check for boost leaks, pre-turbo exhaust leaks, or EBPV stuck partially shut. Also check your air filter.
And no, there is no egr system on the 7.3.
Good Luck
