Originally Posted by epowers777
Do I need to get friction modifier for my rear dually axle and my front axle they say dana on the caps
Only if you have a limited slip or locking differential in the rear. Very unlikely you have a locker in the front. To tell if have a limited slip, jack up your truck so both wheels are off the ground, put in neutral, and spin on wheel if the other wheel spins the same way, you have a limited slip differential, add friction modifier
If the wheel spins the opposite direction, you have an open differential, no friction modifier needed.
Jay 413-222-8286 I got hay for sale
'97 F350 CC, DRW, pickup, 7.3, E4OD, 2wd, 4.10, 405K
'00 F550 reg cab, 11' flatbed, 4x4, 7.3, 6637, 4R100 (soon to be a ZF6), 290k
'97 GMC 5500, getting a transplant, 3.36, sleeper, 350k
Abolish the Federal Reserve, They are the #1 problem.
www.prisonplanet.com
