So these are my recommendations. A40 for the FICM is the best all around program. A80 is fine, but you want to add a PCM tune as well. EGT temps are easily manageable. As far as a rollback, I would rollback, add EGR delete to the programming and probably the 65 tune. This should give you a safe setup until you get studs if you ever do. This should get you started.
I hope this helps
19 F-350 6.7 Auto
16 F-350 6.7 Auto
