Old Tue, April 24th, 2012, 01:13 PM
Virago Virago is offline
Virago is on a distinguished road
I don't see how an intake would effect your CS functioning, but maybe we can help if you give us a bit more information.
What do you mean when you say the CS won't "run"? Are you saying the screen won't light up when it's plugged into the truck? Have you checked your cigarette lighter fuse if that's the case?
Or, are you saying it won't change the program in your PCM to anything other than stock? If this is the case, have you tried repairing the firmware/software in the CS using Fusion?
Or, does it program the truck but then your truck gives you a CEL on anything other than stock?
Give us some clarification here, please.
The device itself functions. When programmed the truck stalls out/check engine light/wrench appear in tow or extreme. Tech said mass air impacted by the air intake. I updated with Fusion...still no luck.
Tech said to talk with Bill at Powerhungry Performance or replace factory air intake.
