Old Sun, February 26th, 2012, 01:39 PM
God & Guns
Default Power locks not working
My power locks have not worked in the 3 yrs that I have owned the truck. The key fob and communication works. The fob nor the door switches will work the locks. I pulled fuse 26 I'm the power distribution box to check it and the truck turned off. Put the fuse back and I was able to start the truck. One of the legs of the fuse looked burned but the element seemed to be intact. I believe I replaced the fuse a couple of yrs ago and the looks seemed like they didn't have enough umph to actuate. Every time i tried to work them it seemed like they were getting less and less juice each time.
When I talked to Bill, he told me Cost was the expert on this issue.
