Think you may have bitten off a lil more than your truck can handle once you get it loaded with water and all your gear. Yet upgrad the brakes on the truck and you should be fine. Towing something that big to me is easier for some reason the bigger the better in my book. Just pull forward far enough to give you enough room to make corrections. If your truck is regeared than you are fine. Mpg aint gonna be pretty with that much weight expect single digits. As far as lifted you will notice more sway than a stock truck just because you are higher up. So go slow around corners and take it easy on it. Other than that happy camping and good luck!
2007 Supercab few mods here and there
