Old Sun, April 8th, 2012, 04:02 PM
God & Guns
Default Glow plugs always getting power!?
I have both negative battery terminals disconnected and have already pulled the gpr. I can touch the ground lead from the volt-meter to the negative battery terminal and the positive lead wire to the wire that feeds the gp's (wires that get voltage when relay is engaged) and I get 13v. Doesn't that mean my gp's are getting voltage akl the time?
Batteries haven't failed in the 3yrs I've had them, but starting is a little slow. GPR is about 8 months old.
