Old Thu, August 25th, 2011, 01:18 PM
mustang_gt_350 mustang_gt_350 is offline
mustang_gt_350 is on a distinguished road
Default manual shifting with chip
Ok, Id like to make a shifting tune where exampe Position 1 is 1st 2 is 2nd and so on. So I'm guessing on transmission test gear select you pick what gear and on trans test switch you have to have it as 1 for on?
Also how do you disable the TC lock? as i would like to be able to control it manually with my hand switch and not have it on the tune.
I beleive this will make it easier for me to drive/tow with my larger setup, instead of having to pull the shifter down into 2nd and lock the switch I can just flip through the gears with the tune and lock as needed with my switch. Also i may set it up that i can control the shift on the track with the sled with my tune so i can go from 1st into 2nd and not have to worry about it hitting 3rd and dieing out.
