Be sure you're not confusing driveshaft bind with a transmission slip. Having lift kit and/or loose carrier bearing will cause bad vibration that gets worse under load and clears up faster you go.
2000 F250 CC shortbed. 5" diamond eye, S&D intake, 4" lift 315's. 3.73's
