I'll try to answer a few of your questions from your other posts in this one.
So the FICM tuner comes with 4 tunes, and no extra charge for them. Its still $400 or $375 this month. You'll get; mileage, A40, A80 and Hercules. You can change them anytime you want to. Its take 2-3 minutes to change between tunes, including pulling the FICM relay. If you want to program the FICM on 4 to 5 trucks(for example) its $150 per truck or FICM. Bill will provide that number of unlocks requested to the FICM programmer. Once that FICM has been programmed by the FICM programmer, it uses up one of the unlocks. However, once that FICM has been programmed by the FICM programmer, the programs(M, A40, A80 or Herc) can be changed as many times as you like, and will not use another unlock on that particular FICM. The same goes for each truck, until all the unlocks are used. Once the unlocks are used, you can still change FICM programs on the trucks that had been programmed by the FICM programmer before. Keep in mind, if your FICM fails, and you get a new one, you will need to purchase another unlock. If you get another truck and want more unlocks, you have to contact Bill, and he'll provide a code to enter into the FICM programmer to unlock it.
Custom tunes on the Gryphon(Same device as FICM programmer just different programming) wont get wiped out by edge's fusion software. The monochrome Gryphon uses PHP's software for updates, not Edge's fusion.
The CS and CTS use Edge's fusion software for updates. The custom tunes can be saved and reloaded if and only if you contact PHP prior to updating the firmware on the CS and CTS.
19 F-350 6.7 Auto
16 F-350 6.7 Auto
