Old Thu, July 22nd, 2010, 10:22 AM
cartmanea cartmanea is offline
cartmanea is on a distinguished road
Installed the older PCM with EBP sensor and the truck runs better with less lag using my larger Garrett PowerMax turbo. I see about 4-5 psi more boost at WOT also. If you have a base strategy like VXAP1 that does not use the EBP sensor, can tuners write custom tunes that do use the EBP sensor, or are they limited by the strategy you run?
