Originally Posted by Longshot270
Put smooth rotors back on and put drilled up front.
Add more power/gear lower/much smaller tires.
Less braking. You shouldn't need to use too much brake pedal to burn the back, especially with the 5.4.
so do a brake swap between smooth front brakes and rear drilled brakes?
that's going to cost me at least $100 eh :p
what do you mean by "Add more power/gear lower/much smaller tires"
how do I change gear or add more power? the tires are the stock ones
thanks!
