Originally Posted by cleatus12r
It's going to run REALLY lean.
Just throwing that out there. There is more to this than just the octane rating of the fuel.
Thanks for throwing that list up there, shotgun!
Cody - why do you say that? I don't think I understand at all.
He's got a "flex-fuel" truck, which has been designed to burn the E85 crap and, like shotgun says, it should adjust the A/F mixture for the proper stoich (9.85) as long as that fuel is being burned.
Are you saying that the canned performance tune will try to hold the A/F ratio at or near 14.64 regardless of the fuel used? If that's the case, I understand and yes - I would not use ANY of the canned tunes with the fake gas. But, as you can tell, I didn't think it would work this way. Can you clarify?
Thanks in advance my friend. Hope you're staying warm up in the frigid north country!
