So this is what I did. I reinstalled the custom tune. The gear ratio was correct. The tire size that was in the custom tune was different than the two numbers that I determined. I determined the tire size using two different methods: 1)by measuring one tire revolution and 2)by calculating using the tire diameter given by the manufacture website. So which one should I use? The actual measurment or the calculated?
