Regarding your trans temp issue. I had the same issue briefly.
After having my Gryphon for a while and not being able to leave well enough alone, I had updated the firmware in Pegasus to the latest available at the time (3.10.1015). After the update, the only thing I noticed different was that trans temp read 'NA'. I then installed the next oldest firmware (2.50.0924) that was available in Pegasus (the only other one available), and trans temp worked again.
I went back and forth on firmware, and it repeated. I had mentioned it to Bill in an email, and he couldn't think of any reason for it to happen, but also mentioned no one else had reported the issue. So, I left it at the second oldest, and transtemp works for me fine, that was a long while ago, and I've not played with it since.
So, it could be same or a different issue. You could check what firmware you have on the Gryphon, but I'd wait and see if Bill has a comment, unless you're comfortable with updating your Gryphon yourself, give it a try.
good luck
Eric
2006 F350 King Ranch
Gryphon & PHP tuned FICM
EGR deleted
4" Turboback
