Closed Thread
Old Tue, November 16th, 2010, 11:38 AM
MO05SD's Avatar
MO05SD MO05SD is offline
MO05SD is on a distinguished road
Question Question about Oasis Report
I was wondering about how I obtained the completed Oasis Report. I posted in the forum thread to get the report done. Now my post has been moved to the completed forum thread. But I haven't received it in an e-mail or PM that I can find. If it just hasn't been sent or however it is done yet, I can understand. I just wanted to check. Thanks
Old Tue, November 16th, 2010, 06:54 PM
Jeremy's Avatar
Jeremy Jeremy is offline
Spark Plug Inhibited
Can you open it in the completed section?
19 F-350 6.7 Auto
16 F-350 6.7 Auto
Old Tue, November 16th, 2010, 07:06 PM
Jeremy's Avatar
My bad...I moved you to completed before it was completed.
Sorry about that...its completed now.
19 F-350 6.7 Auto
16 F-350 6.7 Auto
Old Tue, November 16th, 2010, 09:35 PM
MO05SD's Avatar
Default Opened My Oasis Report
Thank's Jeremy. I opened it in the requested thread. It gives me an idea of whats been done.
One quick question. I see where it was re-programed to the 05E15 on 13-OCT-2006. I bought the truck in September from the local Ford dealership. They claimed they serviced the truck with oil change and fluid checks at that time. I noticed a oil leak and they agreed to fix it. They checked it out and stated it was leaking thru the crankshaft positioning sensor and replaced it. This doesn't show on the report. If they did it, should it be on here and if the re-flashed to a later strategy while it was there, would that also show ? Why I ask is because my fuel mileage is only about 13.5 avg. daily driving and I have the injector buzz and it seems to have the turbo manipulation when it idles. From what I remember, I believe these are in later strategies than the report shows has been applied.
Thanks again.
Closed Thread
