Go Back   Power Hungry Performance Forum > Power Hungry Performance Product Information > F.U. Chip & FU2 Flex Chip (DISCONTINUED)
F.U. Chip & FU2 Flex Chip (DISCONTINUED) If you have a question or comment relating the new F.U. Chip or FU2 Flex Chip, post it here.
Old Thu, March 17th, 2011, 10:01 PM
amd_h4x0r amd_h4x0r is offline
amd_h4x0r is on a distinguished road
Default Towing in HP mode?!?!
I had to do about 600 miles of freeway towing today (about 6500-7000lbs) and I didn't get a chance to swap in some tow tunes on my FU beforehand. I did all my driving in the mildest tune I had which was the 80+HP setting. I was just wondering if this could be harmful?
Maybe it's just me, but when towing my truck felt a lot more sluggish and took quite a bit of time getting up to speed(but I was trying to avoid going above 1000F EGT). Could this be a result of towing in the 80+HP tune or is it in my head? I feel like there should be a lot more get-up-and-go since this truck is rated upwards of 20k.
2002 F-250 7.3 XLT CC/SB -- 4R100 -- 3.73 gears -- 139k miles -- 285/75R16 TreadWright Guard Dog M/Ts -- 3" leveling kit
4" MBRP exhaust -- foil delete -- DIY intake -- zoodad mod -- Wicked Wheel -- Auto Meter Ultra-Lite II gauges -- PHP F.U. 6 position chip
Old Fri, March 18th, 2011, 06:51 AM
cj45lc cj45lc is offline
Hey bud I tow my 9-10k horse trailer in the 80dd tune all the time with no problems at all. I bet it did seem sluggish if you where worried about 1000*egt but your temps would have probably been better if you would go on with it, as in getting the rpms up. You got plenty of get up & go if you just ask for it. The egt will get higher if you lug the engine.
Old Fri, March 18th, 2011, 07:25 AM
Lowdown89 Lowdown89 is offline
EVERYDAY HUSTLER
Lowdown89 is on a distinguished road
I pull my loaded car trailer around on the 80dd setting with no problems, I have a 65hp tow setting but rarely use it as my truck does fine on the other settings, I pull my unloaded trailer around on the 120race setting and dont really see any adverse effects just have to watch the temps close
Old Fri, March 18th, 2011, 11:08 AM
The only things you'll notice while towing in higher HP or DD tunes are an increase in EGT while accelerating at a decent pace (NOT trying to keep EGT low) and early shift points. Otherwise, nothing else is too different.
Old Fri, March 18th, 2011, 11:33 AM
hey thanks for the replies. I was worried about EGTs getting too high but I guess I should only be worried around 1200+?
Old Fri, March 18th, 2011, 12:02 PM
im gonna try out some tunes next weekend(pullin up the cajon pass) i'll report back .
DIY intake
CCV dumped
Autometer gauges
WW/ATS 1.0 exhaust housing
AIH delete/ebpv delete
TruCool trans cooler
Straight piped
PHP FU
