Old Tue, December 6th, 2011, 09:18 PM
Uncle Uncle is offline
Festivus Pole Dancer
Uncle is on a distinguished road
Default having a brain fart...
Ok, I had to send my Gryphon back to PHP, I was having trouble switching custom tunes. Long story short, Bill sent me a new Gryphon (b&w model) so I finally got a chance to put it in the truck last night. Went to program my custom 93 performance tune, and it was only showing the basic tunes not my custom tunes I had before. How do I get those back?I know I have a cd with the program I need to install. I just switched jobs so all that stuff is scattered, but I can find it. Any insight for this dimwitt? Thanks! Wayne
Old Tue, December 6th, 2011, 11:23 PM
Go here>>> Power Hungry Performance - Customer Support
You'll find a download for Pegasus .....
Old Wed, December 7th, 2011, 09:12 AM
The older (pre-04) model Gryphons don't allow their menus to be changed by Bill. Anyway, here's how you check to see if the custom tunes are installed:
Any programmer with a Product Number that looks like --> Ex.xx.xx <-- is an older platform unit. And, on those units, if the last 2 digits are "99" then it is always a custom file.
So, an older model Gryphon with a Product Number that looks like "Ex.xx.99" has custom tunes.
I think you find the product number by following this menu path: [Diagnostics] -> [Tech Support] -> [Version Info] (or something like it).
And, as 88 said, if you need to install the custom tunes, you'll use Pegasus [Updates]->[Custom File Download]. But, Bill may have to put your new programmer's serial number into the database for that to work. If you DO already have the custom tunes installed (I think you should), don't try to update it with Pegasus, you could easily wipe out the installed custom tunes.
Old Fri, December 30th, 2011, 11:45 AM
Ok, it doesn't seem to be a new Gryphon, it looks like the same serial number on this one. I plugged it into the truck, and my HEX code is the same as well. I found my Pegasus disk, loaded the program and tried to find my custom tunes to no availe. Does Bill have to upload them to the server again?
Sorry for all the questions. I swear i did this all fine the first time with no issues.. i am so gun shy with the truck right now, just want to be extra sure i don't hose something up. Spent $1600 on a new PCM last week, and just want my horsepower back!!
Thanks!
Old Mon, January 2nd, 2012, 11:08 PM
Have you gone to the [Custom File Download (internet)] in the Options menu of Pegasus?
Old Mon, January 9th, 2012, 11:45 AM
Yes, i think i figured it out. When my truck locked up when i had the problem with the cable issue, Bill uploaded a PCM recover file to the network that i then downloaded and downloaded. It looks like the PCM recovery file is the one it grabs when i click on Custom File Download.
Is there anyway to ask Bill if he can put my custom tunes back on the server so i can retrieve them?
Old Mon, January 9th, 2012, 01:21 PM
Left a note for php.....
Old Mon, January 16th, 2012, 04:25 PM
Downloaded the tunes today during lunch and am back in business! Thanks for everyones help!
