Old Wed, March 21st, 2012, 02:51 PM
Lilpooh Lilpooh is offline
Lilpooh is on a distinguished road
Default Codes P1378 after FICM programming.
A little info first, I bought the Gryphon non-CS/CTS with 4 FICM tunes to use at my convienence. THIS IS NOT the remote FICM programmer where its a "loaner" then return to PHP.
Prior to installing the Atlas 80, I scanned the truck for codes using AE. Just the normal code for my over head temp/compass that stopped working a long time ago.
After installing the Atlas 80, and going for a joy ride to play with my new found power!!! I was checking out the features of the Gryphon, clicked on read DTC's and found U0306 which is normal because my strategy tunes are VXAP2. The other code has me confused, it's a P1378 low FICM input voltage. So using the Gryphon I checked my FICM volts INPUT, they are holding steady at 13.5.
So my question is.... Is this normal to have a ghost code because of using the Gryphon FICM programmer, or was the code thrown because the FICM relay was removed for uploading the FICM tunes?
Thanks, Rich
2004 F350 CC DRW King Ranch
X-3 tunes by DJ,QT,GH,ID,head studs,II Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,Snow Perf stage II,EGR delete,AD2,4" turbo back straight pipe,K&N intake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod
Old Wed, March 21st, 2012, 05:59 PM
Rich,
The P1378 DTC is a code that is generated by the ECM when the FICM relay is removed during programming. This is completely normal and will alleviate itself after several key cycles, or you may use the FICM programmer's Diagnostic functions to clear the DTC manually.
The U0306 DTC is a mismatch between the RCM and FICM strategies. This code is more of a reference code and is NOT an indication of anything that will affect driveability, so there is no real concern. In order to eliminate the DTC, you must use the correct FICM strategy with the correct ECM strategy. The relationship is as follows:
  • 2003 Model Year:
    ECM: VXAxxxx
    FICM: 2003 FICM Strategy
  • 2004 Model Year:
    ECM: VXBxxxx
    FICM: 2004 FICM Strategy
  • 2005+ Model Year:
    ECM: VXCxxxx
    FICM: 2005+ FICM Strategy
In your situation where the truck was a 2004 but still ran the 2003 ECM strategies, you'll need to use the 2003 FICM strategies.
I hope this is helpful.
Old Wed, March 21st, 2012, 06:57 PM
Thank You Bill.
Tomorrow I'll load up the '03 FICM tunes for my strategy code. Their is nothing like chrome-moly cajones, and since I've got'em, I'm gonna load up the Hercules!!LOL!!
Old Wed, March 21st, 2012, 11:05 PM
Originally Posted by Lilpooh View Post
Thank You Bill.
Dang... stole my line! Of course, I stole it from someone else.
Old Fri, April 13th, 2012, 11:18 PM
speotter speotter is offline
speotter is on a distinguished road
Default FICM Reflash
I had some problems with my FICM (6.0 PSD 2003 Excursion), and I had it reflashed by ford and then I had it rebuilt with higher voltage (not sure what they are called) but they works fine. One difference is that the MPG went from the 15-17 range to the 13-15 range.
Is that due to the CA smog recall 06E17? Did that require a different than original flash for my FICM?
Is that what caused my mileage change?
What can I do to get it fixed?
