Minotaur Automotive Tuning Software Tune your own 7.3L Diesel! If you have a question or comment about Minotaur? Post it here. Also, check out our Facebook group: Facebook - Minotaur Tuners |
How Bout' a "Snow and Ice" tune
I drove up to Denver today in the snow and ice and came up with the idea of a Snow and Ice tune. currently I only had the 60 80 and 100 HP tunes loade. several times when i gave it gas on the hill climb on the freeway the wheels would break loose. Maybe Bill could add this to their selection of tunes for the FU and flip chip. basically we want to avoid wheel slip as much as possible. also want to stay off brakes as much as possible when slowing. Here are some of the things I was thinking about
I think this should also be a good MPG tune as we would be backing off the power and fuel levels :o
DJ Phoenix (my modded) Hi-1200/240Tow/75FS/80DD/100/140SS +Minotaur ASE Master Auto Technician 2001 Ford Excursion 7.3 4x4 Projects. 1970's Hustler and Max II Amphibious ATV's |
Keep the thinking cap on!
Tuning, flashing, burning chips, and repairing all aspects of 7.3L Powerstrokes. SEVEN 7.3L-powered vehicles in the driveway. Two didn't come that way from the factory! |
I thought if you put it in second it still drops to first if you stop or put too much load on?
with engine braking you are forcing the front and rear axle to stay at the same speed rather than one end locking up though.... would be fun to try out some tuning ... at some point Ill get some quiet time to look at my maps and see what I can change Humm what about increasing the amount of torque reduction in the up shift. Im thinking higher throttle position the more torque reduction you would want???
DJ Phoenix (my modded) Hi-1200/240Tow/75FS/80DD/100/140SS +Minotaur ASE Master Auto Technician 2001 Ford Excursion 7.3 4x4 Projects. 1970's Hustler and Max II Amphibious ATV's Last edited by soutthpaw; Wed, October 28th, 2009 at 11:55 PM. |
Maybe make the idle when extremely cold (about -20 to -40)not sound so freakin loud. Kinda scary sounding.
Also I think all the shifts should be really smooth and early, lock the TC sooner than normal to keep RPM's low(below 1800). This is one of the main reasons I want the Minotaur Software. |
Nope, no matter how far into the go-pedal you get, if the selector is in "2", then the truck will be in second. It is a function of the manual valve only (the one hooked to the shift cable). GM on the other hand.... The problem with driving in four wheel drive is that there is ALWAYS the increased possibility of a slide due to ALL tires losing traction. During engine braking, it's not really likely. However, when in 4x4 with a mechanically linked transfer system (like our SD trucks and Excursions have) if one wheel locks up....they all lock. Also during turning maneuvers, the risk of the rear tires pushing the front through a corner is increased....especially with a limited slip rear differential because the binding created in the drivetrain WILL be alleviated through the drive wheels. The factory "torque reduction" strategy is great. The way they are set up in most aftermarket tuning is too harsh. Bill and I have already went into this a little.
I use 5/40 in the winter and have written programs to address this concern relating to SOI vs. EOT and SOI delay when the engine is really cold. I agree with the smooth shifts....always have agreed no matter if it's for icy roads or driving on pavement in the summer. The problem with applying the torque converter clutch earlier is that even though there is less torque available in sub-1800 RPM ranges, the drive wheels get a direct power input from the engine. Conversely, when the TCC is not applied, the slippage in the fluid coupling greatly softens the "impact" of torque application to the rear wheels.
Maybe change the PWM of the TCC to soften its application, and have it unlock immediatly when you let off the pedal, for me any way to keep the R's down would be nice.
Unlocking the TCC on deceleration is also possible. Heck, lots of PCM strategies out there do that anyway. It's possible to change a few parameters and get even a PMT1 to do it.
Is there any harm by doing this? Shouldn't the engine noise level be similar on a cold engine as a warm one? Or are there other things influencing this? I realize that it wont be as quiet but damn this thing can get really loud. As a tuner how would you know when you have gone too far?
The noise level will always be slightly higher with a colder engine because it is working harder just to stay running. The drawbacks to not enough injector "lead time" when cold could be harder starting, white/bluish smoke, and sluggish performance. It takes quite a bit of "less SOI advance" to get these drawbacks so once you get to the hard starting or smoking, you've gone too far with that particular truck. Too much SOI advance is definitely audible and it's something that should be avoided for fear of a junk engine. If you've ever heard of people recommending being easy on the engine while it's cold, it's because of these EOT related maps. There is A LOT of "advancing" going on there. Add into that the increased SOI of aftermarket tuning (RPM vs. Mass Fuel Desired) and you get some pretty awesome timing.
