F.U. Chip & FU2 Flex Chip (DISCONTINUED) If you have a question or comment relating the new F.U. Chip or FU2 Flex Chip, post it here. |
Some one elses invoice in my package?
I recieved my FU package, TS chip, switch and burner today but there was someone elses invoice in my box? all the info was right on the outside. Did I get the right thing are all TS chips the same ie different model for different model trucks?
Before I get to installing this I would like to know I am installing the right thing..........................
2000 F350 4X4, 6"up w/ bilstein 5150s, 20"rockstars, 37" Toyo M/T Mods: Power Hungy Performance FU, pyro-boost-trans, airaid intake, Zoodad, wicked wheel, turbonetics EBV del., IH bellowed, Riff Raff (FRx, HPx, PRI's, OCR, AIH delete, boots,ccv), foil del., 50 cent, 4" turbo back w/Magna flow, Derale, max AC mod, 05 grille, clear headlights, and led tails. |
I'm not sure but I'll leave a post on the moderator forum for Corey.
Hi Tyson,
Looks like we boo-booed. Luckily, the FU chips aren't burned in advance, so it doesn't matter. WHEW! Did Bill already e-mail you your activation code? If so, you can go ahead and burn your chip with the calibrations of your choice!
~ Corey Resting in Peace - 1969 - 2019 |
Thanks Corey, Bill did send me my activation code. I didn't want to get to far, before I made sure it will work in my truck.
So the TS chip I received will work in my 2000 F350 7.3, are they all the same size. Let me know if you need the invoice # of what I received. Would it be possible to get a copy, of my invoice. Thanks for your help.
