Go Back   Power Hungry Performance Forum > Ford F-150, Expedition, Navigator, Blackwood, Mark-LT, SVT Lightning and H-D Editions > 2009 to 2014 F-150
2009 to 2014 F-150 3.5L, 3.7L, 4.6L, 5.0L, 5.4L, and 6.2L equipped F-150s
Old Thu, May 6th, 2010, 08:34 AM
shotgun's Avatar
shotgun shotgun is offline
Gryphon CTS
Question 6-speed tranny gear ratios?
I'm pretty darn sure I saw a post that listed the 09-10 6-speed tranny gear ratios, but I can't seem to find it...
Can anyone me out? Please?
Thanks!
MGDfan Junior V1.0
Old Thu, May 6th, 2010, 08:56 AM
From what seems to be a reputable website:
2010 F-150
1st: 4.17:1
2nd: 2.34:1
3rd: 1.52:1
4th: 1.14:1
5th: .86:1
6th: .69:1
Hope this helps.
Old Thu, May 6th, 2010, 08:57 AM
shotgun's Avatar
Gryphon CTS
Clap
Thank you sir!
Old Thu, May 6th, 2010, 09:00 AM
To me, everything looks great except the ridiculous split between 4th and 5th and that unreasonably high 6th gear.....IN A TRUCK.
Old Thu, May 6th, 2010, 09:07 AM
shotgun's Avatar
Gryphon CTS
You can definitely feel it when you're on the interstate on-ramp, especially when you couple it with the throttle lag.
As soon as the SCT or Edge is ready for the 09-10s...
I'm pretty sure this is how they're trying to squeeze every last MPG out of the 5.4L.
Old Thu, May 6th, 2010, 12:51 PM
SportTractoF150 SportTractoF150 is offline
Black Platinum
SportTractoF150 is on a distinguished road
So my question is in reference to adding 35" tires to the truck.
I know in the 2004-2008 trucks with the 4 speed transmission, 35" tires and 4.56 gearing was pretty much the standard and perfect combination to make up for the power loss and to preserve the transmission.
With the current 2009+ trucks with the 6 speed transmission, what would be the equivalent? I've got a 2009 Platinum sitting on 35's...have been for a year. Should I be concerned about hurting the transmission or it dying prematurely on me? I have been toying the idea around of regearing, even after I pick up the new Gryphon CS or CTS, but I'm not quite sure on:
1) if it's needed to save the transmission
2) which gear ratio would be suitable with the 6 speed transmission.
Thanks!
Old Thu, May 6th, 2010, 02:52 PM
I would definitely get a regear with the 4.56 gears since it has been working out for most vehicles. I'm not sure what your truck came with (I dont think they changed anything though) but look around and find a ratio that will bring it to a little bit (and I mean a little bit) higher than stock. All the regear does is bring the final ratio back to what it should be so it doesn't matter what your transmission is. When you regear the driveshaft and everything ahead of it should be turning at nearly the same speed as it was before the bigger tires.
