Old Tue, July 6th, 2010, 06:30 PM
Pocket Pocket is offline
Default Throttle AD counts question
Under parameters I noticed two settings and was wondering what, if anything, they do... and what would happen if they were changed.
Closed throttle default: 250 AD counts
Full throttle default: 676 AD counts
I'm wondering if changing these (particularly the full throttle default) if I can get a better range of control with my pedal, especially under the MFD table, or if these have any bearing on the MFD table at all.
Thoughts?
I'm going to try changing the full throttle default count and see what happens, but just wanted to see if anyone else has messed with these yet.
Old Tue, July 6th, 2010, 11:06 PM
F-127's Avatar
F-127 F-127 is offline
Tuner novice
Hmm, well I can tell you that I honestly didn't know the answer until you asked. So I opened up Minotaur to see if I could investigate. While you have a project open and have the project window selected, you can select "Mark" on the toolbar and then pick Help. This will bold different variables that help information has been filled in on. Closed and Full Throttle defaults happen to be bolded. You can then select the bold item in its respective parameter, map, function window and press F1. These happen to say "This is the default value used when a sensor error has been detected." Now what causes the PCM to think there is a sensor error I'm not sure.
Thomas H.
Old Wed, July 7th, 2010, 09:28 AM
Those are sensor error defaults. If the APP sensor is open or shorted, these are the minimum and maximum values that are allowed.
Old Wed, July 7th, 2010, 11:56 AM
Ok, that makes sense. Thanks for the info guys!
