Old Sun, December 26th, 2010, 12:14 PM
clayton87 clayton87 is offline
clayton87 is on a distinguished road
Default questions about tunes
I have been running power hungry's canned tow tune for about 3 months now, I love the way it felt, I think the novelty has worn off a bit , now I'm considering getting a custom tune, probably an 87 performance tune, however I'm also considering maybe an 87 towing tune, My only mods are a cat back and a AF1 intake. What I'm wondering is the real big difference between the two tunes. - fuel mileage (city/highway) shift patterns (earlier/later), throttle response between the two and etc. any input is appreciated. Also I do not tow or haul anything, the reason i used the canned tow tune was cause i liked the pickup affect of it, Thank you
Last edited by clayton87; Sun, December 26th, 2010 at 12:22 PM. Reason: forgot something
Old Sun, December 26th, 2010, 04:28 PM
BigSur BigSur is offline
Scientist
I noticed a little more torque at the high end w/ my 87 performance, plus higher shift points. All in all, it's not a "huge" difference if that's what you're looking for IMO. I like mine and plan to keep it.
Old Mon, December 27th, 2010, 02:22 PM
Tonto87's Avatar
Tonto87 Tonto87 is offline
Tonto87 is on a distinguished road
I kinda agree with Big Sur.
However, I went from canned to custom 87 tow and 87 performance. Felt a good change from canned to custom on the tow, while the performance was better on the upper end. Never ran the canned perf. because of CAI installed.
Now run the performance unless towing. Throttle seems a little quicker in it. Love the WOT kick I get when some idiot wont let you change lanes. Gets the big SCrew movin' quicker than they expect. Hope this helps a little.
2004 SCrew Lariet 4X4
5.4 K&N CAI, Flexalite fans
Flowmaster 2.5" True Duals w/ 50 series mufflers & X-pipe 3.73LS
Percision 120 wire grills.
Gryphon CS
Old Mon, December 27th, 2010, 08:50 PM
You wont see the same difference from canned to custom tunes as you did from stock to canned tunes. There will be, however, a better fit to how you drive the truck. If you can give Bill a good description of your driving conditions then he will do his best at matching the tune's parameters to your needs. He will also be able to readjust your sensors to match the larger intake to keep from running lean.
