Old Tue, April 5th, 2011, 01:31 AM
shorty2tall shorty2tall is offline
shorty2tall is on a distinguished road
Default Best CAI?
What's the best cai and which is the best filter to go with afe wise pro 5 pro 7 or dry?
Old Tue, April 5th, 2011, 09:19 AM
Old Tue, April 5th, 2011, 11:30 AM
agreed.. Tymar/DIY only.
DIY intake
CCV dumped
Autometer gauges
WW/ATS 1.0 exhaust housing
AIH delete/ebpv delete
TruCool trans cooler
Straight piped
PHP FU
Old Wed, April 6th, 2011, 12:41 PM
Robert6401's Avatar
I've got the DIY setup now, but have considered going to the S&B or another that would be quieter and is actually sucking in colder air. Is there anything that really makes the DIY/Tymar better other than the cost?
Bob-
Old Wed, April 6th, 2011, 06:26 PM
Default Best CAI?
I like the cost of the DIY setup but like he others cuz they have the shield to keep out the hot engine air out and plus the intake Tube with less groves in it so less restriction
Old Wed, April 6th, 2011, 06:40 PM
cj45lc cj45lc is offline
I really like the Ford AIS for me not looking for crazy high HP numbers. Great filter & keeps the stock look under the hood.
Old Thu, April 7th, 2011, 07:25 AM
Yeah, paper is a far better filtering media than anything else...especially cotton gauze.
Old Thu, April 7th, 2011, 08:55 AM
God & Guns
Is the tymar washable/cleanable? Or do you have to replace it when it gets dirty?
I cleaned my AFE (regular filtering) filter last weekend and the dirt that came out of it was real fine grain.
Old Thu, April 7th, 2011, 09:44 AM
You replace the paper elements (DIY/TYMAR) when they are dirty. I don't know the price of the TYMAR filters but I do know they're cheaper than the ones at NAPA which are around $40-$50 each.
On thing to consider is that paper filters are not water resistant. If you live in a rainy/humid climate, you may be looking at a more frequent change interval due to moisture contamination. Once a paper filter gets wet, it's screwed......
Otherwise, as long as the intake tube/adapter you use for the DIY seals properly, you never have to worry about dirt getting into your engine.
Old Sun, April 17th, 2011, 04:40 AM
Probuilder's Avatar
Probuilder Probuilder is offline
DIY Man
Probuilder is on a distinguished road
I like the Amsoil EAAU4095 -EA with a prefilter EAPF12 -EA, this makes a great DIY setup with 4" exhaust tube to make the piping. Really simple, resists water, dry media, and filters more air. Plus this is a cleanable filter with light air pressure. Filter manager gauge fits right in the end hole so you still know when to clean the filter.
The pre cleaner is water resistant also.
I have been running this setup for over a year on gravel roads and still can't even see a difference in the filter minder gauge. I have cleaned it 5 times (the pre filter and 2 times on the actual filter). I am yet to see any dust on the inside of the tube or filter.
Pictures below.
Thank you and have a great day, Troy Detweiler
I have a '99 F 250 7.3L Diesel w/ a 6 speed Tranny and 4x4.
Mods: Amsoil dual bypass oil filters, Amsoil air intake mod DIY, fuel preasure spring mod(70psi), FU Chip and Burner , 3.73 rear gears, leveling kit (DIY), Stabilizer bars on the rear axle (DIY).
'02 F 350 7.3L, 6spd,4x4,CC, Dually- Just bought 4-15-11
