Old Fri, July 30th, 2010, 07:46 AM
jgrappone jgrappone is offline
jgrappone is on a distinguished road
Default 2006 F250 6.0 liter FICM programming
I am very interested in doing the FICM programming after the dealer reprogrammed my truck to the VXCF9h7 strategy. I run a diablo predator programmer and after the ford calibration my mileage went down the toilet. My question is which besides my driving will give me the better mileage having my FICM reprogrammed or do I need to get it all rolled back. Also if I get it all rolled back what calibration would be in the truck so I can use my diablo predator. Thanks
Old Fri, July 30th, 2010, 09:53 AM
The best way to get your mileage back is to do it all in one shot. Even when the Diablo is installed in the truck with the VXCF9H7 strategy, the ECM is still operating with a crappy base strategy.
Old Fri, July 30th, 2010, 12:39 PM
Okay that will be fine. What will the new strategy number be with the roll back or will it still show VXCF9H7 even thought it is different. When I had the previous strategy from ford and the 100hp tune from diablo I was getting about 23 mpg on the highway not pulling and when towing a 5th wheel would get about 13 mpg with a 13,000 lb trailer.
Old Mon, August 2nd, 2010, 06:16 PM
My current strategy is VXCF9H7 in my 2006 F250 6.0 liter powerstroke and that is the reason I want a FICM programming. My strategy I had before that I liked was VXCF1D6 if I get my ECM and TCM rolled back can I get it rolled back to that strategy? It seems that some people that have had it rolled back by you folks was to a VXCF4D3 strategy and the tunes for the Diablo Predator were not as good with that strategy. Thanks
Old Mon, August 2nd, 2010, 07:19 PM
Jeremy's Avatar
Jeremy Jeremy is offline
Spark Plug Inhibited
If you want VXCF1, thats what they'll give you. Most people go to VXCF4 because 4 shifted better than 1 did.
19 F-350 6.7 Auto
16 F-350 6.7 Auto
Old Thu, June 2nd, 2011, 08:26 AM
ff0326 ff0326 is offline
ff0326
ff0326 is on a distinguished road
I have the exact same set up in my truck. How did the update work? I recieved my email yesterday for the remote programing. What can I expect? I rolled over the local grain scale the other day with the 5th wheel and motorcycle trailer attached. Pushing 24,000 lbs. Was getting about 11 mpg pulling this setup out to Doubis WY then Ford got ahold of it and now 7-9 mpg. Same roads about the same conditions. Doing about 15 empty on a good day. My '04 with the 100 hp installed ran 19+ all day long. If you parked the two trucks side by side, you would not be able to tell the differance, except for the grill.
Old Thu, June 2nd, 2011, 08:37 PM
I see you have an 05 EX. Do you like the strategy that you have, and what kind of mileage do you get? I just got my custom tunes today, and am thinking rollback. Got an 80 DD, 100, 120, and 140. They all shift like butter, and have good power, but mileage still seems subpar. I know I have a garbage strategy, just wish I rolled back before I paid for the tunes, and have to pay again.
SHAWN
Old Fri, June 10th, 2011, 05:51 PM
Jeremy's Avatar
I really dislike the EX's program. It shifts like crap and gets poor mpg. I averaged 14-15.5 when I used the Stock Ex computer. Then I changed over to a Truck PCM. With a 04 F-250-F350 PCM and the PHP FICM I'm up to 17.5 so far...Winter fuel...
I have a summer of traveling ahead so I should have some good base numbers to report. Otherwise the EX is sitting in the garage, so I have not had much of a chance to do any real hard core mpg tests with it. I'd like to get to 20 at 75 mph, but it may not be possible since they're so heavy.
19 F-350 6.7 Auto
16 F-350 6.7 Auto
Old Wed, June 15th, 2011, 04:19 PM
ff0326
Well the upgrade has been in now for a couple of days. Only running to and from work. Before 14.5-15.2 mpg. after about 60 miles or so looking at around 16.8-17. Still too early to get accurate readings, but some is better than none. Will install my programer this weekend and see if that ups it at all.
Old Fri, June 17th, 2011, 04:19 PM
Keep us updated.
SHAWN
