Old Wed, April 8th, 2009, 04:42 AM
jerry edwards jerry edwards is offline
jerry edwards is on a distinguished road
Default Gryphon Guage
Is there a way to delete the MPH and RPM off the Gryphon and put EGT,EOT,TFT,and BST instead?If possible how can it be done?
Old Wed, April 8th, 2009, 09:46 AM
JWBFX4 JWBFX4 is offline
In order to change the display items, Push menu, go down to setup(hit enter),then hit enter for display, then go down and hit enter on the one that says 4 (function?). Then after that just select one to change, and then scroll through the parameters and pick the new one you want. And then repeat this last step for the next 3.
Old Thu, April 9th, 2009, 02:50 AM
Default Guage
Every time I set it up,it won't get ride of the mph and rpm,I can put any other 2 things on.
Old Tue, April 14th, 2009, 10:30 PM
muns53's Avatar
muns53 muns53 is offline
PHP Tuned and Vegistroked
Location: Highland, NY in Ulster County (Hudson Valley / Catskills Region)
muns53 is on a distinguished road
I'm monitoring these:
EGT (uppper left)
Boost (lower left)
Tranny temp (upper right)
Oil temp (lower right)
I followed the instructions in the manual to get me to this point. Good luck!
www.VibrantLED.com -- '02 7.3L Excursion Limited ~135Kmi total; ~50Kmi on WVO
Vegistroke V3 (installed 4/09); HIH, Aux Pump, FPHE (added 11/10); WVO Designs CF
PHP Gryphon; 6637 intake; 4" exhaust; Terminator HPOP; Tru-Cool; Evans NPG+; other goodies...
Old Tue, April 14th, 2009, 10:55 PM
Make sure you go to done or set display and hit enter not menu and I did this once and my selection was not saved to the location.
