Old Sat, May 26th, 2012, 02:16 AM
hpdiniz hpdiniz is offline
hpdiniz is on a distinguished road
Default need info in loading tunes
Got an email notifying the custom tunes are ready for my Gryphon.
I have a few question and looked through the site but was not able to locate the answer. Maybe not searching correctly...
Do I need to return to stock before removing Gryphon to load tunes? Is there a place to get instructions? Maybe instructions are on the CD that came with the Gryphon, now where did I place that CD?
Old Sat, May 26th, 2012, 10:00 AM
RedRocks's Avatar
RedRocks RedRocks is offline
RedRocks is on a distinguished road
Yes.
I couldn't find anything in the manual, but the Q&A by JackandJanet says you should set it back to stock. See the last question, #2.
~Frank
Just because you can doesn't mean you should!
Old Sun, May 27th, 2012, 05:34 PM
Correct! Set the truck back to stock before disconnecting the programmer. Then, start Pegasus (and apply any updates to Pegasus if you see a popup window that says there are any) before plugging the Gryphon into your PC.
Then, when Pegasus says you're connected, click [Updates]->[Custom File Download (Internet)] to locate and start the custom file installation process.
Old Mon, May 28th, 2012, 02:40 AM
Thanks...
One last question, on the order form, I chose to have custom tunes for level one and level three for my Gryphonn. Since I want to keep level two with the canned tow tune, do I need to pick witch level to load into when connecting to PHP or is this already taken of and will automatically load as specified on the order form?
Old Mon, May 28th, 2012, 09:29 AM
Everything's automatic in that respect. The loading will appear to be one big file that knows where things should go.
