2003 to 2007 6.0L Power Stroke Diesel 6.0L Power Stroke Diesel equipped Super Duty and Excursion
Old Tue, April 3rd, 2012, 09:53 PM
Hiteckredneck Hiteckredneck is offline
Hiteckredneck is on a distinguished road
Default my 06 is blowing blue smoke
I have an 06 F350 with the 6.0. The only mods that I have done to the truck is a stage 2 AME cold air intake and 4"down pipe and 5" from transmission cross member back. I eliminated the cat. A few days ago I got on it pretty hard and every sense it has been blowing blue smoke a lot shortly after start driving.But the longer you drive it smokes less and less. It is not using any oil or antifreeze. I have been told that the 6.0 needs back pressure witch I have taken away. So I have been told I will probably need a tuner and or a custom tune. Anyone have any ideas?
Thanks
Rick
Old Fri, June 8th, 2012, 08:56 AM
Cajunrgfm Cajunrgfm is offline
Cajunrgfm is on a distinguished road
Ya, blue smoke is too much fuel in combustion chamber, either to aggressive tune or bad injector, do an injector balance test for mechanical cond. of injectors, before you try to tune it out.
Old Sun, June 10th, 2012, 08:17 PM
IdahoF350's Avatar
IdahoF350 IdahoF350 is offline
Red Bull Junkie!
IdahoF350 is on a distinguished road
If the above suggestion shows no injector performance issues, it could be engine oil in the exhaust stream. Pop the downpipe loose from the turbo and look for oil in the exhaust pipe and turbine housing. A bad seal in the turbo can allow oil to weep into the exhaust housing and that oil will smoke light white to blue under normal driving.
My Truck is a Truck, not a Toy. *I work my truck like a truck is supposed to get worked. *It's got 3800lbs in the bed in this picture, and it's towed over 50,000 miles for me.
My Truck:
2005 F-350 Super Duty, XLT Crew Cab, FX4 Long Bed
Wounded 6.0L (about to be replaced), ZF 6S-650 6-Speed Manual, 3.73:1 Gears
Mods: 4.5" Lift, 35s, 5" Stacks, just a touch of redneck style!
