Gryphon Programmer Edge Product has discontinued the Edge Evolution 2, but we still provide support and tuning for it. If you have a question or comment relating the Gryphon (or Evolution) programmer, post it here. |
HARD shift when passing
Not sure if this is normal or if I should be concerned.
Was heading down a two lane doing 60-65 and went to pass someone. Mashed the gas pedal and my truck dropped down to 2nd for a brief second, high RPMs, and then to 3rd. The transmission shift felt VERY hard, not firm but hard. That normal or should I be concerned?
Specs: 2004 4.6L SCAB | Gryphon Programmer 87 Performance | Magnaflow True Dual Exhaust - Rear Cat Delete | S&B CAI | Summit Underdrive Pulleys | Troyer eFans (ordered) | Smittybilt Bullbar | Procomp 6" Driving Lights | UWS Toolbox | Rhino Lining | Chrome Steprails | 2.5" Leveling Kit | 265/70/R17 Goodyear Wrangler AT's Vids: Magnaflow Startup & Revs - Interior Exhaust Sounds |
try it again, you may have been at just the awkward speed to make it think 2nd was okay to go to.... how fast were you going?
2010 F150 XLT with the 3 valve 4.6 and 6 speed auto |
Yeah, tried it 4 or 5 times in the hour that I was on the road. Same results. Was running about 60 when I'd drop the hammer.
Maybe that's the 15 rwhp you are feeling from the ud pulleys?
You could go into the gryphon and change firmness setting if you wanted to? Or even the rpm shift point? Lars Btw nice specs w/ vids+sounds A+
SENIOR MODERATOR--PTLA God doesn't have a Facebook but he's my friend. God doesn't have a twitter, but I follow him. |
OH and thanks for noticing and commenting on my sig
I see Bill and Corey are back. Maybe the Mad Doctor can chip in
What we might do is:
1) Address the Shift Torque reduction on the 4-2 and 3-2 shifts to soften then up a bit. 2) Lower the 3-2 shift point at WOT to eliminate going form 4 to 2 on the downshift. One or both of those should fix the issue.
Bill Cohron - The Mad Doctor Power Hungry Performance - The ORIGINAL in Ford performance tuning... Since 1996! (678) 890-1110 www.gopowerhungry.com - Home of the Hydra Chip, Minotaur Tuning Software, and the new Orion Reflash System for Navistar! Bring back Windows™ XP and 7. Windows™ Vista and Windows™ 8 is a pain in my a$$! Windows™ 10 is only slightly less annoying! |
OH, and as a side note, I'm mainly just concerned that it's not "right." Possibly going to cause damage if repeated. If that's not the case, I'm good with it as-is!
I can't say if it's hurting something or not, so I'd just rather not take that chance... ya know? If it's not right, it's not right.
The shift points you can handle. The torque reduction I need to handle. I'll give you a shout as soon as it's done.
#10
10-4
