Old Sat, July 7th, 2012, 01:15 PM
Tommy69z Tommy69z is offline
Tommy69z is on a distinguished road
Default Miss and engine light on after running high idle setting
Tuesday I let my truck run on the high idle setting for about 10-15 minutes to keep ac cold, had some meat in car and had to make a stop, anyway, when I came out the truck was missing and the light was on...I cut it off a few minutes later and restarted, the light went off, and the miss gone for the next five miles home. Today, the miss is back and the engine light??? Any suggestions???
Old Sat, July 7th, 2012, 01:18 PM
This is an 02 with a TS 6 position chip
Old Mon, July 9th, 2012, 10:52 AM
God & Guns
Get the code pulled. Possibly a UVCH problem (lose connection).
Old Fri, July 13th, 2012, 07:32 AM
Got the codes pulled yesterday...
P1316, P1211,P0541, P1876, P1832
It showed on a cylinder camparison test that 6 & 8 were acting up, you can barely tell it is missing at idle. On the buzz test, only no. 6 injector barely buzzes compared to the others...now that I have an idea which one I will pull the drivers valve cover and check the harness.
Old Sun, July 15th, 2012, 09:09 PM
It was the plug loose under the valve cover
