Gryphon Programmer Edge Product has discontinued the Edge Evolution 2, but we still provide support and tuning for it. If you have a question or comment relating the Gryphon (or Evolution) programmer, post it here. |
I'm sure most of you have noted that if you check mpg the old fashioned way, the average MPG readings on the Gryphon will be significantly higher than the calculated MPG from miles driven/gallons used. The F-150 is pretty easy to fill consistently but even when the the two values are recoded over a year and averaged separately, I show an average of 14.7 mpg using a g/mile calc vs 16.6 mpg from recording the screen average at every fillup (and reset each time). That's about a 11+ percent difference. Yes, my tire circumference is measured to the millimeter and loaded into the custom settings. My speed and odometer have been checked against mile markers, radar units and GPS and are accurate.
Comments? Other observations? |
I have noticed about the same thing... but with worse mpg's..
![]() That's all I got, anyone else know any better than me? ![]() |
If a true comparison was to be made then.....
Don't reset the Gryphon each time.....let it go for a year....
SENIOR MODERATOR--PTLA God doesn't have a Facebook but he's my friend. God doesn't have a twitter, but I follow him. |
wait... we can reset the Gryphon's average mpg's? Ive never seen nor needed to do this because it fluctuates enough that when I am driving around town it shows 14-15 mpg's(actually getting about 12.5-13mpg's) and when I drive up to denver airport I have seen it climb up to 18, and my trip here to SLC this weekend it got over 20 at a few parts, but I only got 13.5 mpg's averaged out through the first tank of gas... , so I guess my question is why does it fluctuate like that? Ive never seen it stay on the same number for more than a few hours and that is when I was driving home through the flat part of wyoming... and a hours is pushing it, if I hit a big hill it would drop the average mpg's by 1 or 2 on the way up, then they would go back up to whatever they were after a few miles of flatter driving again...
Resetting the Ave. mpg (done by hitting "enter" when the unit is on) because Bill C. that was the way to show the most accurate MPG. When reset, it will go to whatever the instant MPG is reading at that moment and then start averaging input data. IIRC, Bill said that the error stacks up as data is stored. The unit can store only so much data and dumps or overwrites as it goes along.
I just spoke with a guy who uses the built-in Ford unit in a similar truck and he said his reads optimistically by 2-3 mpg as well. I watch instant mpg religiously, to control my driving (try to accelerate while keeping it above 9mpg!) but I'm about to put another parameter in place of the average. I think people don't like to talk much about this because they like the "braggin'" right they get ( : < ). |
If recording more increases your % error then you shouldn't even be watching it to begin with. Your chance of error goes down when the number of samples goes up.
Here is a quick example of why short term averages are bad. For easy math (and since I'm not positive on the official rates other than the data stream rate) we'll say the programmer takes 5 readings per second. Lets say you have two different calculations going. One set of calculations has a small number of readings at 1000 readings and the other has a large number of readings at 10000 readings. If the current average is 16 mpg for both then it is easy to see how a single stretch of road could impact the mathematical formula. You climb up a hill with an IECON reading of 5mpg for the 10 seconds it takes to climb up that hill. Then you slowly roll down the other side of the hill with zero throttle input (maxing out the IECON at 40mpg) dragging on the brakes (to not speed and ram the little old lady ahead of you) for 15 seconds. Your average in this section of road is 26 mpg according to the programmer. Factor that into the "small" calculation and once you are back on the road your average is 17.1. The large equation comes out to 16.1. If you then compare to the "full" amount of 100,000 readings, you end up with 16.0, or no noticeable change. Keep in mind, this is the impact of only 25 seconds of drive time, now consider what happens when you are cruising through traffic or hilly areas where you are switching between the gas and brake pedals as well as changing speed often. If you were able to freely roll down the hill to shorten the recording time, the average would not be thrown off as much. Unfortunately the computer cannot account for elevation changes, lack of throttle input, resistance from wind and tires, etc. Until then the average will not be completely accurate except under ideal conditions.
![]() Quote:
![]() Quote:
I haven't tested this in a while but I bet if you used the cruise control all the time the average may be more accurate. Part of the inaccuracy is from letting off the pedal while rolling. All the time you spend braking is counted as 40 mpg per reading. I think back and the computer rarely uses 0 throttle so you wont have nearly as much 40 mpg getting thrown into the mix. Only problem is you can't use cruise control in varying traffic. The only reason I look for ways to improve mileage is because I'm cheap and need to stretch the tanks. You might be able to get some girls out in Del Rio, last time I was passing through I wanted to take my time. ![]()
Ok Jim,
I'll agree on the overwritting data but the most accurate data comes from 4 tank fulls of gas ...that's the optimized amount of samples according to Bill with out reseting each time....
#10
So I just got back from utah, and I have had at least 5 tanks of gas since the last time the gryphon was unplugged, and it still varied from 14.x to 17.x on the average mpg's I had it in cruise control most of the trip except for the stops and when I made sure to not hit the people going 10 under the speed limit
![]() ![]() My worry still is that mine is fluctuating too much, aka more than it should and more than everyone else's is... but I am happy about the 15 mpg's, I got only 13.7ish on the way to utah... :/. The trick in Del Rio is to figure out how to outshine all the other brand new 2nd Lt's that are girl hunting! haha ![]() |
