Gryphon Programmer Edge Product has discontinued the Edge Evolution 2, but we still provide support and tuning for it. If you have a question or comment relating the Gryphon (or Evolution) programmer, post it here. |
I have the 35x12.50 R18 Nitto Trail Grapplers. I believe the Revs/mile is 592 so I divided that by 1,609,344. To get 2718.48 I entered 2718 as my TS but the Gryphon is still off my speedo. What should I do?
The Gryphon will NEVER read the same speed as the speedo.
Once the tire size is loaded, just watch the speedometer and find a different parameter to watch on the Gryphon screen.
Tuning, flashing, burning chips, and repairing all aspects of 7.3L Powerstrokes. SEVEN 7.3L-powered vehicles in the driveway. Two didn't come that way from the factory! |
Clemson, the TS you entered looks pretty close.
What Cody was trying to tell you is that the speedometer in the dash always reads about 2-3 mph higher than it should due to mechanical effects. But, if the Gryphon shows a correct speed (which you can verify by a GPS among other methods), you've set things up correctly and your odometer will be correct. Now you can use the dash speedo and hold a speed 2 mph above the speed limit and be legal (at highway speeds)! ![]() - Jack
2014 F150 Platinum SCrew 3.5L EcoBoost 4x4 with SCT programmer |
Thanks for the help guys. Ill try to match the gryphon speedo with a GPS or something of sorts to make sure my odometer is correct.
-Chase |
