Old Thu, January 26th, 2012, 10:17 AM
God & Guns
Default Engine perimiters
Hello guys I got my Aeroforce gauge installed last weekend. I was just wanted to get some info so I know what some of the engine perimiter values I should be seeing, such as exhaust back pressure (seeing about 30 at idle and about 50 if I punch it real quick while cruising), coolant/oil temp, torque converter slippage, IPR duty cycle (I'm seeing about 7.5 at idle and 22 cruising at 70), Injector pulse width. I'm seeing about 500psi on the ICP at idle. Here's a video of the gauge doing the cycle mode. I haven't got the kit yet to get the egt reading, so not running it too hard. I'm also going to get the sensor kit to read fuel pressure. I pulled 2 codes when I first got the gauge and thought I had stored them on my phone before I cleared the codes, but guess I didn't save them.
