Go Back   Power Hungry Performance Forum > Ford Super Duty & Excursion > 1994˝ to 1997 7.3L Power Stroke Diesel
1994˝ to 1997 7.3L Power Stroke Diesel 7.3L Power Stroke Diesel equipped F-Series and F-Super Duty
Old Wed, June 22nd, 2022, 11:42 AM
Chris77 Chris77 is offline
Chris77 is on a distinguished road
Default Will Hydra Tuner work with transmission shift kit?
I'm very interested in this tuner but will it effect transmission shifting. I have a Bully Dog shift enhancement kit that I installed several years ago. The kit consisted of 3 springs and a valve. I'm concerned with having overly harsh shifts. Thanks
My truck is a 1997 F-250 Automatic. E-fuel, 1.0 housing, 4 inch exhaust, downpipe, Tymar style intake, Soon to be intercooled. RSK, Solid axle swap
Old Wed, June 22nd, 2022, 12:01 PM
Chris, welcome to the forum. I'm sure Bill will see your thread soon and I think he can provide a custom tune that will work well with your shift kit.
You didn't specify what brand tuning device you are interested in. Is it SCT or Bully Dog? Or, is it Billl's Minotaur software, or, something else?
Old Wed, June 22nd, 2022, 02:08 PM
Default PHP Hydra
Sorry, i should have added what tuner i'm interested in. I'm interested in the PHP hydra tuner.
Old Wed, June 22nd, 2022, 03:19 PM
OKyDoaks - I changed the title of the thread to better alert Bill.
Old Thu, June 30th, 2022, 09:43 AM
For many calibration sets, we offer a "VB" (Valve Body) tune set which eliminates the pressure modifications to the tuning so that it doesn't interfere with the mechanical modifications. If you could let me know what your PCM code is, we can let you know if we already have tunes for that application.
Thanks.
Old Fri, July 8th, 2022, 02:28 PM
My PCM code is TDE0.
Old Sun, July 10th, 2022, 08:31 PM
Default Wow
i received my hydra chip this Friday and discovered that there are tunes for modified valve bodies. I installed the chip methodically per the video instruction on hydra help and the chip is working great. Ive only been running the 40 horse DD tune so far because I have an old tired transmission but WOW!! Ive owned my truck for 15 years now and this is the first time its ever been chipped and the first time I ever saw any black smoke come out of the tail pipe. Im impressed! I did notice one thing though...when I press the up or down button on the hydra selector switch it takes a few clicks of the button before it responds. Is this normal.
Old Mon, July 11th, 2022, 10:38 AM
Chris,
The Hydra switch serves two functions, to change levels and to change LED brightness. In order to manage this, there are certain timing specifications that must be met.
To change position, the button must be pressed for no more than ˝ second (quick tap).
To change LED brightness, the button must be pressed and held for about 1˝ seconds (long press).
Anywhere in between those two time periods, and nothing will happen.
I hope this is helpful.
Old Mon, July 11th, 2022, 03:21 PM
Right on. That makes sense. Thanks for the info.
